Monsieur Remings
- Yatton UK
Argh, lucky it wasn't worse. Took a left turn too late, let a few other riders through, unclipped and locked my rear shoe into the chain stay. Felt a right tit. Over I went.
Anyhow, the shifter got 'shifted' over and I'm wondering, despite putting it back into its original place whether there is anything to tighten it up with to the handlebars, so it's likely not to move again? It's a SRAM Rival. Can't find the Allen/torx screw if there is one..?
Also, the shifting mechanism seemed to be working okay after a while but to begin with the gears were skipping when I put any power down - miles from home it would be a bit of a problem. Gradually however, it seemed to be okay and I am presuming, though not sure, that the extra distance of a cm or so from where it was bent further towards the right (it was the left shifter) may have caused or contributed to the skipping being that the tension would have been temporarily mucked up? Is this likely, or is it likely to have been something else and what? The cage wasn't damaged.
Also, what spoke key do I use for Ksyrium Elites. The spoke nipples are way too big for standard spoke keys so I am presuming they need something that does its job inside the rim on top? They are 2011. I really don't know how I ended up with a couple of cms knocked out as a result of this impact, being largely side on...?
As always thanks for any feedback.
