First 100
Yep I finally got round to doing my first ever 100 mile ride, just over 1 year since I started cycling to work on a BSO.
Absolutely knackered even though I did it slower than I hoped, 8hrs 40 mins at an average speed of 11.8 mph. I had 30-40 mins worth of rest stops and also had to back track up a very steep hill to retrieve my phone which escaped from my jersey pocket at 35+mph!!! It still works but has a few scratches on the case.
I have now become terrified of long twisty downhill sections after nearly coming a cropper on a 20% incline above Llangollen (where I lost my phone), bone shattering ride on the surface and blind bends when the rims are getting very hot from braking. I probably should've walked down as I really think I could've killed myself, I will leave high speed descents to nice smooth and open roads which are safer and more fun, the Horseshoe Pass comes to mind.
I had to walk up a section at Glyn Ceriog which ramps up to over 20%! It was torture trying to crawl up it, even in my lowest gear I wasn't getting up it on two wheels.
Anyway here is the route which I uploaded to MMR.
http://www.mapmyride...s/view/41637086
well done on your first 100 miler
aberal
Midlothian
Well done mate - no small feat the 100 mile-er.
Pigo
Suffolk
Very well done! The achievement of the 100 is fantastic & with those hills you should be extra proud of yourself! I'm also with you on the scary downhill thing....I chicken out early on & get off to walk!
Holdsworth
Holdsworth
Crewe, Cheshire
After that ride my knees were knackered, so stiff and painful I could barely move them after a few hours, better now though as they seem to have been freed up. My cleats are set up to match the natural outward pointing nature of my feet and I have no problems on my commuting machine, the tourer. It is just the road bike that gives problems and I believe it might be the saddle. I think it might be too low but the post is seized into the tube and won't budge, alloy stem and steel frame.
BikeLiker
Wirral
Good on ya!. 100 miles is my target for this year but I'll be contour dodging - planning on the the flat bits of Cheshire- hats off to you for incorporating Glyn Ceirog!
Banjo
Fuelled with Jelly Babies
South Wales
Congratulations on completing it.Not a bad time for that sort of country.:thumbsup:
