fatblokish
- In bath
I work for a community charity that has an interest in, amongst others, learning how to make charcoal.
Now, having researched a wide range of methods, the most suitable one for use uses two barrels, the smaller of which fits upside down in a larger oil drum.
Anyways, the oil drum will be stood vertically on its end and cut open (yes, the risks are known) about four inches below the top, all the way around the circumference to create two open ended barrels, one short the other tall. The side now measuring 4" will be tweaked with a hammer and or slits formed so that it telescopes into its larger twin, to create a tightish fit.
Now what happens when the whole barrel is subject to a great heat and the expansion that this will bring? Will the small twin slide downwards, will it pop upwards, will nowt happen? And when it cools, will we still be able to separate the two unequal halves?
As I say, fire and physics...
ta
ta
