ren531
- Lancaster uk
i did find out it has an unusual 26inch wheel size 32-597 and not 590 like my other 26inch wheel bikes so very limited choice of replacment tyres hope you all like it as much as i do.
It's easier to go 700c plus you get a better tyre choice, I had new Aluminium rims laced onto the original Sturmey Archer rear hub and matching rim laced onto a front dynamo I had knocking around on my Raleigh City.Another nice old steel Raleigh back on the road! The more the merrier.
It's funny you should say the tyre size is really unusual, because my Raleigh Arena gas pipe racer that I had in the early 80's had 26" x 1 1/4" (597) steel rims (may have been Weinmann ones from memory) and it wasn't considered an odd size then and tyres weren't a problem for it. I'd expect 26" x 1 3/8" (590) roadster wheels would fit straight on to your Lenton, so long as the brake blocks will adjust, and I know you can still get good tyres like Schwalbe Marathon in the 1 3/8" roadster size.
It's easier to go 700c plus you get a better tyre choice, I had new Aluminium rims laced onto the original Sturmey Archer rear hub and matching rim laced onto a front dynamo I had knocking around on my Raleigh City]
The bike looks great and it raises a question in my tiny mind ?? l have been trying to get proper, ie rational advice on the size of bike frame suitable for me.View attachment 458434 View attachment 458436 View attachment 458423 View attachment 458425 View attachment 458426 View attachment 458428 Just finished the Raleigh Lenton i bought late last year , i posted some photos of it on here before i started the project , its all original i touched up the white lining on the frame and laquered it cleaned greased everything replaced most of the bearings and chain got some replacment period mudguards because the originals where brittle and in many bits and i am very pleased with it, had a short ride on it and every thing is fine, i did find out it has an unusual 26inch wheel size 32-597 and not 590 like my other 26inch wheel bikes so very limited choice of replacment tyres hope you all like it as much as i do.
The simplest calculation l have found so far is to take your individual "standover" height ie the distance between the floor and your crotch with your feet together, in cm, and then multiply by .66.
Thanks for that info. l will compare that method with the method l described and see if there is a happy mediumStandover height needs to take into account the type of footwear being worn. It can make half an inch difference between wearing a pair of thick-soled work boots and, say, a pair of light canvas leisure shoes. For me it varies between 34" and 34 1/2" depending on footwear. The tallest standover frame I ride is an early Raleigh Pioneer hybrid, 23 1/2" size, with a crossbar height of 34" I ride another, slightly later Pioneer, also 23 1/2" frame size, which has a crossbar height of 33" The only difference is the earlier frame has more BB clearance, like a MTB, the later one is closer to being a general purpose road frame in clearance.
In my case, with a high BB frame, the comfort/safety limit for frames I ride is my standover clearance in heavy boots minus 11 inches. Given that you ride racing bikes, which sometimes have a high BB clearance to allow pedalling round corners without pedal strike, you will probably not go far wrong with your inside leg measurement in cycling footwear minus 11 inches.
Edited to say there used to be two widely-used "rule of thumb" frame sizing measures; one was inside leg in bare feet minus 9 inches, the other one was height in bare feet divided by 3. Inside leg tends to give a bigger result. For me the height measurement works perfectly, as my ideal frame size is 23 1/2" whereas I am not really comfortable on frames of 24" or over, although I may be able to physically ride them. Its the stopping and starting bit that is the issue.
