finally fallen off
specialized1980
Regular
PR2
Well had the bike since end of May done between 700/800 miles an today i had my first fall whilst clipped in. Looks like i won't be out for a while as my rear derailieur is above the cassette and trying to get between my spokes.....
Woody5110
Regular
Oops how did the fall come about??
specialized1980
specialized1980
Regular
PR2
Took a sharp turn too quickly, it was on a cycle route and was covered in them stupid tiny stones.
I'm fine thanks. bit of a scratch on my shoulder thats about it.
Born2die
Your not the only one my mind wandered for a mo at mile 30 on Sunday next thing I know I'm riding up the verge clipped in no hope and I look a tit in front of the only car and bike rider for miles
Ern1e
Lets hope it's not as bad as it sounds ! it may only need a bit of adjustment (say he with fingers crossed) Main thing is you are ok and able to tell the tale.
specialized1980
specialized1980
Regular
PR2
I suppose it could have been alot worse...just gutted as i set myself a challenge of doing 100 miles this week so was happy with near 30 on day one....now i'm flipping stuck there.
Bummer indeed. Main thing is you ain't broke.
It sounds like you have bent the rear hanger. It can either be replaced or bent back but by the sounds of it bending it back might snap it any way. A new hanger costs very little and a decent LBS will do the work and realign it for you. Shouldn't cost too much at all.
specialized1980
specialized1980
Regular
PR2
Wow, that's some mess. LBS time. Again though hopefully it's mostly the hanger.
If are handy with the bike you could always remove the chain and undo the derailleur - if you can get access. Still LBS will have the right tools for the job. Hanger alignment tool costs about £60+ so defo worth having it done instead of buying.
Snarf
I also had my first fall at the weekend, so snap!! I was on a dual carriageway and wanted to stop, I unclipped one foot and then leant the other way to put the other foot down, which was obviously still clipped in! Luckily I fell onto the verge, but I did manage to shout I'm falling" to no one whilst I was going down!
