@mikeymustard ...its grim oop north mate...gonna get some gloves (I'm a bit nesh as we say up ere) see if i can do 3 miles tomorrow :$
@raleighnut ...I think breaking your femur..! gives you a good excuse, though it sounds like you've been busy that 'fettle list' never gets any smaller though does it? If you're anything like me soon as you get close to finishing one, you go buy another heap ...
I did also manage to buy one of these
Assemble it myself (Delivery was £50 assembled or £10 boxed so a bit of a no-brainer)
Then converted it into this
Which has been my transportation for the past 18 months.
Modifications are 26" electric front wheel kit (original was 24" but if I'd fitted one that size I couldn't use it on a normal bike once I'd finished with the trike) so the forks were changed to suit. North Road handlebars (aluminium) fitted to replace the steel 'apehangers' and a 400mm seatpost fitted with a B17special to replace the sprung foot-wide 'armchair' size seat (that weighs about 5 pounds) 1 brake lever swapped from the 'handbrake' button type to an electric 'cut off' type.
I'd already left off the (heavy) steel mudguards and the basket so a couple of handmade brackets allowed me to fit the rack which houses the battery pack and fitted a 'throwover' type pannier set.
All the standard components have been saved so if I choose to sell it (once I don't need it anymore) it can be returned to factory spec and the electric kit fitted to a normal 26" wheel MTB (for trailer pulling duties)
This all came about when my physiotherapist got me on an exercise bike and said "It's a shame you haven't got one at home) so I thought about that, then about getting a 'turbo trainer' and bolting one of my bikes onto that then suddenly thought "If I get a trike I can go places on it" (neither Maz or myself drive) I'd looked at 'prebuilt' electric trikes but they were in the region of £1600-£1800, I managed to build this for just under a grand.
EDIT - The curly 'telephone' type wire wrapped around the frame is from the Electron lamp set to its battery pack and isn't part of the conversion, the wires for the wheel are almost invisible.
