Felt Z85 reveiw
Doyleyburger
NCE West Wales
Iv had the felt for just over 2 months now so I have had time to reflect on the pro's and cons of this bike.
Purchased whilst it was on offer (down to £650) from Tredz.
First ride was a quick 8 mile loop around town and I instantly felt comfortable on it and it's 105 group set was sharp and precise. Although the frame geometry is built around endurance and comfort I can easily use it for short rides where I can put the power down.
I recently took it for a 4 day London to Paris trip and it performed exceptionally well..... In fact i wouldn't have wanted to ride anything else.
The stock felt tyres are ok and roll good enough, I shall probably keep them through the winter months before upgrading in the spring. I was advised to change the brake blocks straight away as they were apparently the only down fall on the bike, however they seem fine to me, although the bike has been lucky enough not to see any rain yet so I can give you my thoughts on the brakes later perhaps. The bike comes in at around the 9kg mark which is very good for an Aluminium machine ( carbon forks and seat post) and in good time I shall be making a wheel upgrade which will lighten the bike some more.
I instantly changed the saddle upon purchase as the stock one looked a little too spongy, which I'm sure wound have been fine for maybe 25-30 but by then I'm sure my sit bones will be telling me to make my way home.
Previous bike was a giant defy, a bike which gets great reviews all round so I was a bit nervous about switching to the Felt but I have definitely made the right decision.
Done over 600 miles on it now so I gave it a tune up last night and its all ready to go again now. I highly rate the Felt Z85
BrynCP
Hull
I have a 2013 model and agree with the above.
2250 miles in 6 months and just a single puncture (two weeks ago) on stock tyres/tubes. I had to replace the rear hanger and it was in stock at the LBS and the rear wheel but this was due to theft damage, not the bike its self. The original rear wheel also needed a touch of oil under the rubber part on the hub (technical aren't I) when it started to make a high pitched noise. Other than this everything else is original still and fine.
Brake blocks I find are fine on the dry flat, where they seem to be a bit dodgy are the wet and descents. However, once you know how they react, they're fine!
Jamieyorky
York
I also have a 2013 Z85, just clocked 1500 miles tonight on it, its my first road bike and i love it, the bike feels great and happy if your just out for a steady ride or out to push it hard, i droped the stem down a large spacer to give it a more race feel. The only thing ive done is changed the saddle for a pro logo kappa but apart from that mine is stock, i will upgrade when things brake.
