Hi all, ive just bought a Felt FC frame set from eBay and maybe be concerned over nothing here but....
Does the lower fork bearing run on the fork taper or should there be a metal ring placed on there first?
About time someone started making forks like that. The crown race is an anachronism dating back to loose bearing headsets and is just an added headache on A-Headset types.
That will not happen because it is not a race. It is merely a seat. The bearing, being a cartridge bearing, has a built-in race - two in fact. But should that happen, you'll only have to buy one fork, not many, as in, one fork, many forks.
You won't wear it out, the bearings run inside the sealed cartridge. "Race" is actually a bit of a misnomer as all the crown race does on an integrated headset is locate the cartridge bearing centrally on the fork steerer, just as the taper inside the head tube does.
