Felt F95 (2013)
RebornBumbler
Barnstaple
Initial experiences and impressions of buying a new road bike - Felt F95 2013 - ~£450 from several outlets. At the time of posting I've had it for 4 days...
I bought mine unseen/untried from Winstanley - they had it in Monster Green and I didn't fancy the Wiggle Special colours, nor the similar standard "Anthracite".
Other than picking a colour I liked and minimising the price I was paying, my criteria were:
A major manufacturer.
New-style integrated shifters (up and down the gears regardless of hand-position).
9 Gears minimum.
It came packed in an undamaged box which was a good start and it required very little thought to unpack and put together (I still haven't read any of the paperwork...)
The bars/controls, gearing and brake pads had all been nicely sorted before removing to pack up, so there was little required other than simple assembly.
Once quickly/loosely put together, I copied the crank-centre to saddle-top height from my old Ridgeback and figured out roughly where I needed the bars rotating to in the stem (I went for an almost straight-line to the hoods from the top of the bars). Threw on the pedals/toeclips from my Ridgeback hybrid thing and checked the pedalling action which required moving the saddle back a tad (by feel, I don't subscribe to KOPS - what's gravity got to do with pedalling ?). Having nipped-up all the bolts, I decided there was no way I could live with the saddle (before I'd even ridden it down the road), so I swapped my Madison Prime over from the Ridgeback - relatively total bliss.
A quick spin of both wheels had me sweating a little, as there was perhaps 3-4 mm of sideways movement - mainly on the front - but a quick twang of the spokes suggested a couple were quite loose, so I blindly tightened them a touch and checked again - just a mm or two then. A little further tightening in the right places and I had as perfect wheels as I've ever had, and was pretty chuffed with myself to boot :smile:
(I've since had to do some more tweaking, but I figure that's probably the case with most new wheels).
Finally pumped up the tyres (to around 90/100).
I have to say that my initial thoughts were that the whole bike felt somehow 'fragile' - it felt like it might bend or crumple as soon as I put any significant forces through it - but I've since realised that this is due to it not resembling the "immovable object" Ridgeback that is my only current comparison.
First spin down the road was eye-opening and invigorating. Acceleration doesn't come anything like as easily on a Ridgeback 520 - even when significantly upgraded. I threw it around a few corners with blind faith and the experience was sublime. Braking wasn't quite as impressive - certainly not up to V-brakes with Aztec pads standard - but not alarming. One slight hiccup was a slight grating/graunchy noise/sensation every crank rotation which I thought was probably the not-Shimano square taper bottom bracket bearing. I dismissed it as an immediate problem and prepared to ride it the next day with my local club.
I had determined that I would try cleats on this bike (always used toeclips previously) so went to the LBS and bought a pair of Shimano 520s and Specialized trainer-type shoes. Spent about half an hour putting the cleats in the "somewhere-near" position and a further hour riding around town repeating to myself "CLEATS!! UNCLIP BEFORE STOPPING! CHANGE GEAR EARLY! CLEATS!!!" - which worked out OK.
The pedals hadn't made any difference to the graunch, but it hadn't got worse.
Yesterday's ride was phenomenal - I probably overdid my 'turn on the front', and suffered quite a bit towards the end of the ride on the hills (around 35 miles I think), but speeds were well up on anything I've managed to sustain before. The weather was mostly foul, but I was never concerned with traction or grip - only with avoiding the deeper water and potholes.
We did briefly stop and I immediately (of course) fell over after unclipping and leaning the other way (CLEATS - IDIOT!!) No damage to the bike at all (IT didn't even touch the ground...) and nobody laughed, which was nice.
Handling is precise, but it's not remotely twitchy (On a previous racer I could barely take my hands off the bars). It doesn't tend to shake the teeth out of your skull like the Ridgeback, and just as soon as I adapt to the new position (and fine-tune my cleats /stem/saddle) I predict a very long and happy relationship.
After the ride there was considerable black mess (brake block) removed from from the rims - at least partly due to poorly finished joins on the Alex rims which I've treated to a little fine emery-paper.
I think I'll replace the pads with Aztec roads when the current pads wear out - which might well be quite soon.
I have since been playing with the barrel adjusters, and think perhaps the grinding may be the chain/front derailleur, but I'm not 100% certain until I ride it again.
So to summarise:
The negatives: The brake pads aren't fabulous. The saddle is dreadful! The joins on the rims aren't that well finished and the spokes needed a bit of tweaking. There's a yet-to-be-resolved crank-related grating. The Sora front derailleur action is very clanky/clunky (but this seems to be a Sora feature).
The positives: Everything else! - I haven't grinned-like-an-idiot so much for a long time - it's a fantastic handling responsive ride - I'm also impressed with the Zaffiro tyres - might well stick with those or upgrade to the lighter folding bead variety if I don't suffer too many flats.
I think I'll be getting a 12-27 cassette to help me up the hills a bit (and I really don't need a 50/11 top gear) and I'll swap the pads soon, but otherwise I'm very impressed.
The Green is also truly Monster :smile:
format
Glasgow.
This thread needs pictures :smile:
raleighnut
9 Gears minimum.
So to summarise:
:welcome: To the "Clipless moment" club :eek:
Glad you enjoyed it! I've just got a new bike and also have slight grating noise when climbing in the lowest gear...I'm presuming that the front mech needs adjusting slightly (hopefully!).
R
RebornBumbler
Barnstaple
Update:
Determined that there was no problem with the bottom bracket (which I think is an FSA item - I'll likely replace it with a UN55 if/when it wears out) - the noise was a combination of the front derailleur (small adjustments have almost completely eliminated it except in crazy front/rear combinations) and a couple of stiff links in the (Sunrace) chain.
I've now (as I suggested I might) fitted a Tiagra 9-speed 12-27 cassette and a KMC X9 93 chain. As a result, it's quieter, lighter, changes better and looks better for about £28 and I'm less likely to need to get off and walk!
I've replaced the white 'plastic foam' Felt bar tape with Cinelli black cork, and Aztec Road Brake carriers/pads are on the way.
Doubt I'll be doing anything else to it for the foreseeable future, as it's now just about perfect :smile:
I'll try and get a decent picture up soon.
R
RebornBumbler
Barnstaple
Here we go
- with Madison Prime saddle, Black Cinelli bar tape, 12-27 Tiagra cassette, KMC Chain and a pair of Elite bottle holders.
Pointy boy
Nice review, and pretty much matches my experience of the 2014 F95 (which I believe is basically identical). For simple smiles-per-£ it's hard too see how it could be improved. Yes, the Sora derailleur is a bit agricultural, and the Zaffiro's aren't the best, but frankly none of that really matters when you're cruising along with a big grin on your face. Just a great bike. Mine is in the matt black finish, but I have to say that green looks ever so nice!
bikeman66
Isle of Wight
Your review mirrors my experiences on the F95, especially the slight grating sound. Will be giving the chain a look over tomorrow to see if there are any stiff links. I've only had the bike a few weeks (seriously good bargain at £365.00 from Merlin Cycles) and it is my first road bike for years. Overall, I'm really pleased with it, and impressed that it actually weighed about 0.2kg less than advertised. I'm thinking I'll probably upgrade both front and rear mechs to Shimano 105 if anyone can confirm that they would be compatible (which I'm thinking they are). I realize the Felt F95 isn't some super light full carbon piece of bike porn, but to me it represents a really good and well equipped bike at sensible entry level money. Believe me, I trawled through goodness knows how many reviews of bikes in this category and the F95 was consistently well rated, and at £365.00 down from £599.00 it was a no-brainer! The main reason I bought this bike was (and you'll think I'm mad here) to have a crack at riding to the top of Mont Ventoux. I drove up the Bedoin route while I was on holiday in Provence back in August and was so inspired by the constant stream of men, women and young kids climbing their way up the 22km incline, I just promised myself it was something I would achieve before I was 50 (which gives me about 20 months). I've set late April 2015 as my goal, so me and the F95 have got some work to do over the winter. Would have liked it in white, but Merlin only had the 58cm in black at the time (which I actually still think looks cool).
Only just joined this forum, so Hi to all you guys out there.
Drago
105 rear mech will be fine. You'll need an older 8/9 speed 105 front mech, as the 5700 cage is too narrow and won't trim properly to provide clatter free riding across the gear range.
No grating noises on my F85, though that's a 10 speed chain.
