FD braze on or clamp
ayceejay
Rural Quebec
Is there an advantage in one above the other? The braze on is lighter but if you need an adapter (as I do) there is no weight advantage - so?
Cycleops
Accra, Ghana
Take the change out of your pocket.
ayceejay
ayceejay
Rural Quebec
No sir the weight doesn't bother me at all but this is what is discussed elsewhere is why I mentioned it. Are there any noticeable differences in efficient or adjustment/set up is my concern.
Cyclist33
Warrington
I have a suspicion that with braze-on fitting on a regular shaped seat tube, you can get the wheel closer in than with a clamp-on.
Not sure what advantage that brings... shorter wheelbase so nimbler handling?
Stu
