False Hills or Climbs
PaulSB
I realise this isn't really a technical question but I can't see where else to ask.
On my local training runs I have two false climbs. By this I mean despite being able to see I'm riding up hill I'm either accelerating or at least maintaing speed. These are not short bumps. Occasionally I come across this when further afield.
A friend who is a fell runner says he encounters the same thing. His theory is the power output / effort perfectly matches the gradient in this situation and helps maintain speed / pace.
Two questions then do people think his theory is correct and is it possible to change riding style to gain this benefit more often?
amaferanga
Bolton
If it looks like a hill, but your speed doesn't decrease for the same effort then it's not a hill. Some kind of optical illusion probably. Try riding it in the other direction and see how it seems that way.
As above, it is just the lay of the land giving the your brain the illusion that it is a hill.
False flats are more usual.
ColinJ
Puzzle game procrastinator!
These are optical illusions.
There are several deceptive stretches of road that I can think of round here.
There is a false flat on the A646 between Burnley and Todmorden. It looks flat but it actually rises at about 2%. (It is obvious coming the other way). 2% isn't steep, but when tired after a long ride, I have often crawled up that drag and wondered why I am going so slowly.
There is also a climb above Hebden Bridge that looks a lot steeper than it actually is. It comes straight after a steepish climb up to a RH bend (from the Hare and Hounds in Old Town, heading towards Midgley). The road appears to be climbing as steeply as before but I can accelerate up the second section in the same gear that I was grovelling in just before the bend.
The most dramatic example that I can remember was in Snowdonia. My g/f and I had gone for a ride on hire bikes and came to what looked like a 4-5% climb but our speed kept going up. It wasn't long before we were doing close to 30 mph. It was the most bizarre thing I have ever experienced on a bike. My brain was telling me that we were climbing but we were clearly on a significant descent. I'm sure it was just misleading visual cues from the slopes of the surrounding hillsides, treelines etc.
PK99
SW19
c.
putting some numbers on that:
150lb rider on the flat @ 15mph = ~100W
on 2% slope = ~ 200W
http://bikecalculator.com/wattsUS.html
That sounds about right. It feels like the brakes are dragging - enough to make it feel harder than it should, but not enough to be an obvious climb. Streetview of it.
Looking at the contours on the OS1:25,000 map it looks like it could well be slightly downhill. The easy way is to try a roll test - starting from stationary does your bike roll forwards or backwards under gravity - or to take a spirit level with you and find the slope direction.
ColinJ
Well, it isn't a consistent gradient, but overall there isn't any question about it, it rises up about 40 metres over 2km or so. It is a slow drag going away from Burnley, and it is easy to do 25-30 mph in the other direction - it just doesn't look that way!
I bow to local knowledge.
