acuna_read
- London, UK
I have been looking to reduce my current set of bikes and at the top of the list is the Fairlight Secan but is there anything else I've missed and should consider?
I'm after a versatile bike I can do everything on, although I have an old beater for commuting and a Brompton for city hops. I'm looking to do some longer Audax rides in the next year or two moving onto LEJOG as a build up to potentially attempt some of the bigger stuff such as PBP and Transcontinental in a few years. I also want to do some light touring, up to two weeks at a time in Europe on various surfaces with London to Norway scheduled for next year, so needs rack mounts on the rear. Would also need to be my leisure bike to just go for rides, normally around 50 miles depending on day but can be more or less. With the addition of a dynamo the Secan would really be at the limit for my budget, £2700, so any other suggestions would have to be within this including dynamo wheel.
Currently have a Genesis Equilibrium Disc 631 Reynolds (not stock bar the frame) so I like steel and have experience of it. Also have a Ridley Noah RS which is my fast/summer bike so not adverse to this but not sure carbon is the right material for my intended use in case of breakages from crashing. So the new bike essentially has to replace both of these and then some!
Any suggestions on other bikes welcome, or if you have a Secan and can offer your experience as well.
Thanks for any help.
