oldgreyandslow
- Farnborough
Anyone suggestions to alleviate it? I go to an osteopath regularly for back maintenance as he has diagnosed facet joint problems, when I get an attack the lower back muscle spasms and I lean to the right, usually a trip to the oseto sorts it out but I try to fix it myself if it goes between visits. not particularly succesfully in most cases.
I'm trying to work out what kicked this one in, probably ramped up the mileage a bit too much too soon, maybe pushed too high a gear, did a longer walk than usual, all possible factors. But this time it's not as acute as usual so I'm stretching, twisting etc and generally being as active as possible. Dr Google has helped a bit.
Any other sufferers on here with a suggestion or two? Or better still any tips on how to avoid an occurence and still get the miles in!
