Hacienda71
- Wilmslow, Cheshire
I am a bit of a bargain hunter and hate to pay over the odds for things, so when I needed a new set of pedals as I had, had an N+1 moment I was loathe to get a new set of pedals at full price. So after a bit of a browse online I decided that a pair of Exustar pedals would be worth a try. I had tried Outland/Raleigh look compatibles in the past but they were a tad heavy and not as tight as proper Looks although ok on a budget. I have done 10000 miles on my current Keo classics in all weathers with no issues other than they are starting to get a little creaky and need some periodic greasing and lubrication, so the new pedals will need to impress
The Pros
Lighter than Look Classics at 128g per pedal. Thermo plastic bodies
£20 plus delivery (At least half the price of Look Classics and not much more than a new set of cleats)
Made under licence from Look so fully compatible.
Tension Adjustment.
So here is what you get in the box. First impressions good, couple of obvious differences from the Looks are, the tension adjustment screw is more exposed in the pedal body and the Exustars use an 8mm allen key or a spanner on the axle to tighten, iirc the Looks take a 10mm allen key and they dont have a spanner option.
So I fitted them to the bike. The only gripe I noticed after they were fitted was that if the back of the pedal was at 12:00 the pedal did not spin round so the front was at 1:00. I put this down to the bearings being new and a little tight over greased.
So I went on a ride using the Look cleats that I have on my shoes rather than fitting the new supplied red ones. First impressions good firm solid and easy clip in when riding no issues. Unclipping is fine. So far I have put about 50 miles on them and can't fault them although they are still a tad sluggish to self right. I will post up again when I have put a couple of thosund miles in them to give an idea of how they are holding up through a British winter.
The Pros
Tension Adjustment.
