Probably pinched.
If not, check hole where valve goes through the rim. If car-valve-sized (Schrader) hole and you have Presta (high pressure) valves on your tubes, a tiny bubble of rubber will creep through the oversize hole and go bang when there is no other apparent cause. There is a special insert available to prevent this.
