[quote name='swee'pea99']Forks, slightly bent out of true - not much...but too much to be ignored. Has anyone ever straightened bent forks and can offer some advice on how to go about it? Do I just grab a fork in each hand and pull? Or apply leverage somehow? Any advice very much appreciated. (Oh, by the way, these are old steel forks - nothing fancy.)[/quote]
It's hard to do well, and if the bend is only slight, you may just end up making things worse.
If you decide to try, make some careful measurements beforehand, and get a firm idea of where the problem is, and what needs to move to correct it. Is the crown twisted? Does one leg need to move more than the other?
Avoid pulling one blade against the other - you don't have any control over which bends first. Try to clamp the steerer and bend each blade individually. It's easy to overshoot. Measure as you go.
In a pinch I've stood on the headtube with the fork mounted in the frame and pulled on the blades one at a time. Ugly, but it worked.
It's probably easier to find a used replacement fork.
