Ever recharged your car's AC?
swee'pea99
If so, d'you know whether the blue thing is a cap that needs to be removed for the brass bit to engage?
I was expecting the brass bit to just screw onto the can, but the thread isn't quite engaging. It feels like it would if the blue 'cap' was removed to expose a thread underneath, but it doesn't screw off easily (by hand) and I'm loath to start levering it off with a screwdriver for obvious reasons. Anyone been here before? Thanks if you can help.
Cycleops
Accra, Ghana
Looks to me as if that is some sort if capping on top. I should use small screwdriver to tentatively prise it up at the edges to see what it reveals. If not removed I don't see how it can ever connect to the brass fitting.
Threevok
Growing old disgracefully
South Wales
I concur.
That looks like there should be a pin inside the hose mounting, that punctures the blue disc on installation
Check the other end of the hose
swee'pea99
swee'pea99
Thanks. It's definitely the right end - the 'peg' like thing you can see at about 9 o clock is one end of a screw-in tap to puncture the seal. I suspect cyclops is right, but I'll wait in case anyone knows for sure before prising anything off a super-pressurised can! However tentatively!
There are a few on Amazon, but you could be throwing your money away if you've got a leak. The only times mine went was leaks - holed radiator and a cracked pipe - the pipe was easy to spot as the dye had come out.
derrick
You need a vacumn pump to completely discharge the system before refilling it.
Drago
Plenty of places do a re-gas for £50, and that includes a pressure check. The DIY approach doesn't seem any cheaper?
My nearest place is £35 for an empty, dry, and refil with the correct refrigerant and oil. Used them once and they were very, very good. That said, it's brave and commendable to attempt a DIY top up, and I'm interested to see how it goes.
