epic tyre ware advice please
scouserinlondon
When giving the bike a bit of TLC I noticed some pretty nasty ware on the rear tyre.
I'm riding a Trek Valencia I'm about 13 stone and have the tyres pumped up between 90 and 120 (maximum rated) running botranger hardcase pu@cture proof tyres.
This worried me though, they've probably done about 1100 miles in six months. Seems there are some quite deep scratches, probably caused by a ped related emergency stop on a bad road surface.
My question is should I just replace them, are they okay, is this level of ware normal? And, if I am to replace them, should I go for marathons?
GrasB
Nr Cambridge
Unless you can see the underlying carcass construction then just ride on them until you start getting an unacceptable level of punctures.
Steve Austin
The Marmalade Kid
Mlehworld
That don't look too bad. 1k for a tyre isn't good, but it wouldn't bother me too much if thats the wear i was getting.
As GrasB said, keep using till you start getting P*****s, or you start losing grip.
