I have had an Endura Venturi jacket since Christmas it is the new version proclaiming PTFE protection on the sleeves.
In the current down pours it has started to make a decent impression of a £150 sponge letting me get wet.
So I decide to follow the care instructions in order to revive it's water repellent properties, they are simple to follow:
Wash at 30 degrees with non bio washing detergent and then iron (presumably after it had dried) on a low heat to activate the
water repellent. Has it done the trick? No I still have a £150 sponge.
My questions are is Nikwax suitable for this PTFE protection material whick I presume is the same as the technical fabrics or should I send it back to Endura and say that your product does not respond to the care instructions that you recommend?
Many thanks.
Colin.
Many thanks.
Colin.
