Aspiringbiker
Hi, my bike has been sitting outside for 2 years unridden. I cannot fill the tires because the air is so low I can't get the valve on without air leaking. What do I do? Take the tires off?
It's a standing pump with a gauge on it. I think the valve on the tire has to be on the part of the tire close to the ground. I tried to press the tire up so the valve would come out but to no availPush / pull the valve up so you see more valve stem allowing you to be able to get the pump on. What kind of pump is it?
Not sure what valve typeWhat valve type are you having trouble with.
I will try againUse your thumb to push down on the tyre where the valve is while you attach the pump. This works best when the pump can lock on to the valve.
Is the valve like a car tyre valve?Not sure what valve type
I wonder why they produce such short valves at all. To cut cost of the stainless steel?As above push on the tyre where the valve is, the pump should lock on, if you are still struggling then it is likely you have short valves (presta I’m presuming), I had a similar problem made worse as the presta valve wasn’t threaded so had no lock ring to stop it pushing into the tyre.
If you really can’t manage it then replace the inner tubes with long valve ones.
