Marie Attoinette Fan
I never had any problem with my old Edge 305 holding its charge but I got a replacement and it does, some days if I havent used it for a while its held its charge 100% and battery life is good. Other times I can leave it charged for just a couple of days and when I come to switch it on the batteries are flat. Looking on the Web it seems quite a common problem, basically when you disconnect the unit from the USB even though it looks off the unit thinks its still on; its best solved aparently by turning it on and off manually after charging. Just passing on a tip.
