ECG Gel
jimbut
Anyone know of a really good substitute for ECG gel to use on a HRM chest belt ( Polar T31 ) ?
gb155
Fan Boy No More.
Manchester-Ish
There is something I use every single day
SWEAT :biggrin:
edwardd67
Renfrew
Are you having problems picking up your heart rate?
I hade a similar problem due to being a bit hairy :biggrin:
I tried shaving it and it works , i only shaved a diamond not my whole chest.
Now the hair has grew back i just dampen the hair and the monitor and it works fine.
Garz
Squat Member
Down
I too just go to the hot tap trickle out warm water and dampen the pads. The premium garmin strap doesn't even require wetting, but my other two standard types do.
The Jogger
Spain
Camcare Ultrasound Gel
I asked at Boots and they ordered it for me, it lasts so long I forget how much it was but under a tenner and works better than all the alternatives. KY is not as good for results :biggrin:
zacklaws
Beverley
You beat me to it! I used to spit** on the sensor and wipe the saliva across with a finger.
** Saliva only - phlegm-covered sensors aren't pleasant! xx(
How disgusting, spitting on the sensor xx(, I like to give mine a good lick, its the only time it gets cleaned of the old sweat and grime on it and also gives me a good top up of electrolytes :biggrin:, Anything to recycle waste.
