SatNavSaysStraightOn
Changed hemispheres!
- ɐᴉlɐɹʇsn∀ 'ɐɹɹǝquɐƆ
Having one of those insane, do I know what I am doing moments prior to leaving on my first solo tour tomorrow morning...
(OK so nothing new there except of for the first solo bit..
Can someone please confirm that with an eccentric bottom bracket, the adjustment should not leave the thinnest part against the adjustment nuts? That is the one position that is 'bad' isn't it?
so the adjustment in the picture is the exact opposite and is OK. can't get the change to even vaguely the correct tension if I take it either side of that - new chain and it needs to stretch a touch.
Piccie is with the bike upside down
)Can someone please confirm that with an eccentric bottom bracket, the adjustment should not leave the thinnest part against the adjustment nuts? That is the one position that is 'bad' isn't it?
