ebay forks
rob willock
Regular
cheadle
Iv just recived some secondhand forks off eBay but I'm having trouble getting the wheel in the center of the fork. Any ideas?
Tango
Preston Lancs
Is the QR sitting correctly in both sides of the drop outs?
It could be as simple as that
If you put the wheel in the wrong way round, does the wheel steel drift off to the same fork leg, could be a fork problem or does it drift of to the other side in which case it's more wheel related
Can you borrow a wheel off someone else to try
Not the most intellectual response and there will be people drop by with far more tetchy knowledge that can advise
Before you do anything get it looked at to be sure
rob willock
rob willock
Regular
cheadle
Well Iv managed to get it on right but iv noticed that the fitting for my caliper is different do i need some sort of adaptor?
rob willock
rob willock
Regular
cheadle
There was some sort of an adapter on the caliper so it could b screwed to the side of the old fork but on the new fork they screw into the back. Iv taken the adapter off and now the disc hits the back of the caliper b4 it screws in
rob willock
rob willock
Regular
cheadle
Yer 180. Looks like im off to the northwest mountainbike shop 2mos as decathlon and halfords couldn't help
Cubist
Still wavin'
Ovver 'thill
You need a F PM/PM 180 adapter. The Northwest Shop should sort you out, but they're cheap enough .
If they don't let me know. I've got some machined spacers and extended bolts that will do the job.
02GF74
^^^^ what he said - the adpater moves the calliper away from the wheel by 20 mm ... and as you have said, you will need longer bolts;
...... but not necessarily as some design of this type of adapter have the adapter bolt to the fork and have another two holes for bolting on the calliper, in whcih case you would need 2 more bolts.
(bolts will be M6 )
Cubist
Still wavin'
Ovver 'thill
Generally speaking the bolts come with the adapter but it pays to check.
[pedant mode on] the adapter moves the caliper 10mm further out as the rotor's measurement is diameter, not radius^_^ [/pedant mode off]
