Manonabike
What combination of cog / chainring combination would offer the easiest gear to climb steep hills? A 28t, 30t or even a 32t large cog With a 30t small chainring
) coupled with the largest number of teeth on the sprocket at the back will give you the lowest gear.RedBike said:However there does become a point whe you're pedalling but going nowhere quickly. At this point its probably easier to get off and push.
Ian H said:The easiest gear is always the lowest one you've got.
)Gary D said:In general, the smaller the number of teeth on the front chainwheel (as an engineer, I hate using the term "cog") coupled with the largest number of teeth on the sprocket at the back will give you the lowest gear.
Others may talk about "gear inches", but a very quick way to work it out for comparison purposes is just to divide the number of teeth on the chainwheel by number of teeth on the rear to give you a ratio. Therefore, 30T front with a 30T rear gives a ration of 1. Likewise a 28T front with a 32T rear will be 0.875.
If you want to go in to gear inches and gearing have a look at Sheldon Brown's website:
http://sheldonbrown.com/gearing/index.html
Good luck.
Gary.
jimboalee said:How heavy is the bike?
How steep is the hill?
How overweight are you?
Garz said:There is no 'easiest gear' as it boils down to personal fitness and the type of bike (laden tourer/mountain bike will weigh lots more than say sportive bike). Then there is what your 'step hill' actually is..
