smokeysmoo
- Bolton, not very far from Nob End
Had to strip the front wheel down on my fixed gear after I found a very loose spoke nipple. Tightened the screw, replaced rim tape, re-fitted Marathon+ and tube, started to re-inflate with track pump, got to about 90psi and........
That's the second time this has happened, (not doing the same job though). First time was in the living room on a different bike, (my God that bugger reverberated), this time was in the shed, slightly better than in the house, but still feckin' loud.
My worrry afterwards was that if adrenaline is brown, I feared I was bleeding to death
Don't know why it happened, perhaps I nicked the tube, perhaps I trapped it, (Durano+'s are a bugger to fit), I don't know. It was a chinese branded tube that was original fitment on my Langster Steel, but I'd guess most tubes are manufactured in Asia and the rest is badge engineering, (to a degree at least).
Stripped it down, fitted new Conti tube, took extra care re-fitting tyre, re-inflated, (at arms length), and everythings good again.
Just thought i'd share this latest tinkering mis-hap - seem to have got away with the rim and tyre not sustaining any damage, will take a bit more care on tomorrows commute until I'm happy in my own mind.
Ride safe
Ride safe
