I have an e-bike with a single chainring on the front. The chain comes off the chainring when I change gear. The people at the place I bought it say it's because I change down more than one gear at at time. The mechanism is such that if you push the lever you can shift one gear or several gears depending on has far you move the lever. If shifting more than one gear can cause the chain to come off, why to the manufacturers not limit the lever movement to only shift one gear?
