Dynohub / hub brake front wheel - Sturmey Archer hub XL-FDD / Chrina Rigida rim
Gatley
Front wheel with hub brake and dynamo - it is a Sturmey Archer hub XL-FDD with DT Swiss Competition double butted spokes and a Chrina Rigida rim - it has done about 9,000km. The rim obviously has no wear on the brake surface. I’m not sure how to judge how much wear is left before the hub brake needs the service kit, but it was working fine on my final commute on it. It was a bit of a fiddle to get the reaction arm collar in just the right place and get the adjustment just right so I’d like it to go to someone reasonably competent rather than stick it on eBay and risk getting a return from someone who doesn’t understand how to fit it. £50
Plus I have misc. other items on ebay at the moment:
http://www.ebay.co.uk/sch/amasidlov...e=STRK:MESELX:IT&rt=nc&_trksid=p2047675.l2562
mjr
Rim size?
amasidlover
Gatley
OK - if someone has a use for it then they can have it for the cost of postage (or free if they can collect). If they have a spare rear 6 bolt disc compatible, Shimano/SRAM 9/10 (or 11) speed compatible rear hub or wheel they want to swap for it, then even better...
amasidlover
Gatley
OK - its yours, @mjray - if you're only using the hub can you check with whoever is building it whether they are happy working from photos of the previous lacing and indentations on the hub. If so I can re-use the rim for another project and save you a bit on the cost of the postage.
  • Like
Reactions: mjr
mjr
Sorry it took a while to get an answer now that better weather means bikes are getting prepared for use again. Yes, hub and photo of previous lacing would be fine, thanks. Send me details of how to pay the postage, please.
