Dynamo
Okeydokey
Is there a thread I can't find here? I am interested in any views on ye-olde dynamo system to power the lights front and rear. I gather wheels have these built in now, sounds plausible to me?
I've got a dynamo wheel I borrowed from someone 2 years ago. It's brilliant. The new (German) lights are bright. Only problem is the whole setup is quite expensive.
Fab Foodie
Kirton, Devon.
Agree with all of the above.
Yes you need a new wheel, but one with the better Shimano hub is not stupid pricey (Spa cycles) had some good deals.
I've gone from none to 2 dynamo hub powered bikes and they are a revelation.
Big benefit is that they are always ready to roll without battery and charging faff ....
Okeydokey
Okeydokey
All makes perfect sense to me, thank you all! I have front suspension so would otherwise consider the bottle type generator.
KneesUp
You could always put a bottle dynamo on the back? They are much less efficient than the hubs though I believe.
ushills
Don't bother with a bottle dynamo, they are horrible.
Have a look at rosebikes for dynamo gear, as they are German the prices are much better due to them being more common over there.
I can personally recommend the B&M Cyo and Shimano dynohubs, really good lights and perfect for road use.
Pale Rider
I have an Alfine front dynamo wired to B&M lights on my Rose trekking bike.
Does the job well, the headlight throws a reasonable beam and the back light stays on for a bit when you stop at a junction.
Have you thought about mounting the lights and routing the wiring?
My front light is built into the fork bridge, and the rear wiring is hidden under the mudguard.
A retro fit could be fiddly to do neatly.
Okeydokey
Okeydokey
Thanks Pale Rider. Tbh! I don't really do 'neatly'. If I see rust on my bike I hit it with spray on Hammerite, my bike is blue, the Hammerite is black, works for me. I am concerned though about the light mounting. I see the B & M stuff with fittings that don't compute. Looks like it should have more to it than it does, I am though converted, or will be when the post turns up.
