acuna_read
- London, UK
I'm after getting a dynamo wheel/set for Audaxing and touring/bikepacking whichever you wished to call it. Need to be QR and disc brake as I have decided to keep my current Equilibrium rather than changing for the next year, although my decision on that seems to change with the wind. This however means that they will have a relatively limited shelf life of a year or so as the next bike is likely to be thru axle (unless the standard has changed again by then) and would therefore like to spend as little as possible. I'm looking to use the dyanmo for lighting and charging devices/batteries.
Based on this I'm probably looking at an SP dynamo rather than a SON so any suggestion on wheels or builders which are suitable, had a look at Spa cycles and they seem to be as good a deal as any unless anyone has suggestions for alternatives?
Thanks for any help.
Edit: QR, disc and 700c if anyone has anything second hand which may be suitable.
