steveindenmark
Is there a dynamo with 4 connections. Or is there a way I can run lights and charge a power bank at the same time?
looks like the definitive word on the topic. I think the gadget's manual/instructions alone will be valuable.I think it is done by people who tour. See http://www.peterwhitecycles.com/ewerk.php
Busch & Muller also make a light with a charging option. It is called the IQ2 luxos u. Here is an extremely dull film all about it
View: https://youtu.be/-Wh_S5rJOvI
That
This one's a bit less expensive?
http://www.ebay.co.uk/itm/Universal...485066?hash=item25b2ad328a:g:HxEAAOSw3ydVyBvs
I would not use a bottle dynamo, it would have to be a hub dynamo. I have a solar panel charger but it would have been useless over the last few days. They do need considerable amounts of sun to work properly.
I thought of going for the USB-Werk but I like the flexibility of the e-Werk and I'll primarily use it for charging a power bank, so no cache battery required (and the cache battery in the USB-Werk was a bit small for my needs). I'd be interested in how you get on with the USB-Werk though.
Psmiffy. If you get time, could you post some photos of your set up? which handlebar mount are you using?
