I use the CYO60 (B&M) with a Shimano hub. I've been very pleased with it.
I've done comparisons with my Hope Vision 1, which is generally thought to be one of the brightest front lights running on conventional sized batteries. It's not precise as it's subjective, and the beam patterns are different as is the colour of the LED.
With a B&M Toplight (rear) running at the same time I can't tell the difference between the CYO60 and the 3rd (of 4) brightness levels on the Hope. If I disconnect the rear light the CYO is definitely brighter than the Hope on 3 but less bright than the Hope on maximum (4).
The CYO is more than enough on its own, most of the time, with the rear light running. On unlit country roads I normally have the Hope on as well, at level 2 (of 4) to show up the kerb/ bank on the left. My only serious criticism of the CYO is that there's a gap in the lighting near to the bike when it is set up according to instruction sheet, but I believe that has been improved on the recent ones.
If you want a flashing light, front or back, you'll need to have additional battery lights. That's because German research based law bans flashing lights, and the big market for dynamo lights is Germany. In practice I have run with both dynamo and battery since I had my first dynamo in 1963 (my dad was keen on having the diversity to make sure there was still a working light if there was a fault. That was in the days of filament lights though).
Another issue is lighting when stopped. If you buy the standlight version of lights they stay lit for several minutes after you stop moving. Not as much of an issue if you have battery lights as well.
