drop bars on mtbs
Licramite
wiltshire
Hi , been looking at Mountain Cross ? - seeing mtbs with drop bars , what do you think.
the bikes don,t seam to have suspension on them.
just wondering if anyone has experience of them, I need something to make my mtb more roadworthy as it goes like a wheelbarrow on the roads , better riding position might help I was thinking.
RecordAceFromNew
Swinging Member
West London
The two issues arising are incompatibility between a) drop bar sti indexed levers and mtb front mech if you have a Shimano triple system (since road and mtb front mech chainline and cable pull requirements are different), and b) brakes (since road and mtb brake cable pull requirements are different - unless your mtb has canti's). In other words if you have/want canti's and only want a double chainset then it is relatively easy.
Otherwise drop bar brake levers (not sti) do exist for V brakes. Similarly one can get thumb/bar-end shifters for the gears. But choice is limited in both cases, and you lose the convenience of having brifters.
Is the mtb feeling like a wheelbarrow because it hasn't got high pressure slicks? Or have you tried a) flipping the stem, b) longer stem, and/or c) bar-ends to give you a more aerodynamic posture?
Cyclist33
Warrington
Presumably by "mtbs with drop bars" and no suspension, you mean cyclocross bikes?
Which are more in the spirit of road bikes with off-road tyres than mountain bikes with drop bars.
I strongly suspect the mtb sluggishness you describe is because full off-road tyres make riding on the road sluggish in almost every make and model of tyre. So put some of these on and have done with it...
http://www.wiggle.co.uk/schwalbe-ci..._campaign=uk&gclid=CM2owueU8LMCFWbKtAodVWEAXw
Peter88
Failsworth
+1 for the City Jets the 1.5's are faster but the 1.9's look better on a MTB. The 1.5's also run at a higher pressure 80psi compared to 65psi for the 1.9's. Have used then for 2 years now had 1 p******e and replaced the 1st set 2 weeks ago after wearing them out.
Drago
The Urban Fringe
I used 1.9 Cityjets thinking that a 242+lb ruder and crisp country roads would make them a necessity but they're total overkill. I'll use the 1.5s next time.
zizou
I think you may mean monster cross rather than mountain cross. Basically these are mostly like cyclocross bikes with clearance for wider tyres and simply adding drop bars to a mountain bike (particularly a 26er - you might get away with it on a race orientated 29er) isnt going to make it a good ride as the geometry is going to be all wrong.
Try getting some slick tyres and a set of bar ends, that will help you with speed on the road.
Licramite
Licramite
wiltshire
Monster cross - thats it. - what the hell is that?
yea I have knobbly tyres on the Mtb I should get a set of Off road/On road tyres
and fit the bar ends, I've fitted my clipless pedals and want to train on those , If I'm going to fall lets make it free from traffic and soft (if not spiky ) just waiting for the ground to dry out or its take the water wings with you.
last foray into the woods . I was carrying the bike past a swamp, slipped, ended up on my bum, the bike dropped and cracking me right on the nose, helmet saved me as I pushed it off it fell back so I head butted it out the way. nose bled like buggery.
oliver
oxfordshire
My monster cross!!! - best non road bike I've ever owned! - not to many compatibility issues if you stick to shimano 9 speed
Licramite
Licramite
wiltshire
Hmmm maybe this is what I,m after , hazard a guess it has 27" wheels 48/42/34 chainring 18gears - or similar
allot of my longer routes pan out at 50/50 track-trail/road so the old Mtb is great for half the job and rubbish for the other half. At present I have to take my tourer/hybred which isn't ideal on the off road bits.
looking on the web it seams the classic monster cross has no suspention , which might be a bit bouncy.
cheers, shall have to check out my local bike shop.
Bodhbh
Singular do a drop barred MTB - the Gryphon. Also the Peregrine, which you can setup as a 'monster cross' bike with fat knobblies and drops.
http://www.singularcycles.com/shop/index.php/frames/singular-gryphon.html
I had a Peregrine with fat semi-slicks and drops for mixed surface riding, but it was far to big for me and had to get rid of it. Hrmm it's an expensive job sticking drops on a MTB on the off-chance it'll feel better, expecially (for me at least) it will stretch out the reach past what is comfortable. Just got into the LBS and ask for a fitting, or some free advice on the position?
GrumpyGregry
Here for rides.
surely a monster cross has 29-er / 700c wheels?
drop bars on 26-er mtbs - I quite like wtb mountain drops, and on-one have some good ones too. They make a lot of sense on paper on 29-er mtbs as they get the weight low on the front end. But they'll always be a bit of an eccentric('s) choice.
