Drop bar angle
Garz
Squat Member
Down
Not measured mine..
Banjo
Fuelled with Jelly Babies
South Wales
Fiddled about with mine and found them most comfortable with the bottom bit of the drops horizontal.
eldudino
Bike Fluffer
Stirling
The top of my bars and the flat of the hoods slope backwards for a comfy position. Looks slightly odd on this photo with the old Tiagra on my winter bike, but it looks fine on the summer bike with Sram. Either way, it's comfortable for me, the hoods facing down doesn't suit my wrists (broke the left one when I were a lad). Get it set up to suit you, and do it before you tape the bars!
EDIT: The pic below is slightly confusing, the top of the drops actually runs in-line with the angle of the stem.
swee'pea99
I was once told the ideal starting point is to imagine a line drawn straight along the bottom section of the tube, continue it for a couple of feet, and have the bars set so that that line runs directly thru' the bolt that secures your back brake to the frame.
subaqua
What’s the point
Leytonstone
dunno, not looked . its just comfortable howe it is . will need to look laters
