overmind
My other bike is a Pinarello
- Reading, Berkshire
I am thinking of changing the way I maintain the drivetrain on my commuter bike.
I have a 21 speed (amazon purchased) cheap racing bike. I use this bike for commuting. I ride about 50 miles per week on it. When I had ridden it for approximately 4 years with zero drivetrain maintenance (apart from oiling) the chain used to jump. It got progressively worse until eventually the chain would just slip over the freewheel.
At this point I was going to bin the bike but after doing some research (and watching a few youtube videos) I decided to replace the chain (£6), freewheel (£10) and chainset (£FREE, old 2nd hand one from a 1980's Raleigh).
Since then I have been checking the chain length and whenever it reaches approx. 0.5% stretch I have been replacing it. I have probably been using up about 2 chains, and 1 freewheel per year with this method.
Recently I checked the chain and discovered that I may have left it too late as it is between 0.75% and 1% so if I replace the chain I will probably need to change the freewheel as well. So I have decided to just ride the thing into the ground on the basis that the last time I did this it lasted several years.
I am wondering if this is actually a better strategy than replacing the chain every 6 months and whether it will work out cheaper. The only drawback I can see is that I may wear out the chainset also but in my case I have about 4 spare ones on these from old bikes (I got these from a bicycle recycling centre for about £2.50 each).
Any thoughts ? What would you do ?
