drilling bigger holes in rear discs
02GF74
... just an idea. most bikes have 160 mm disc front and rear (I'm alking shimano and do know they come in bigger sizes for the front).
anyways, we all know the brunt of the braking is taking pace at the front.
so how about making the holes in the rear disc bigger to not only save a couple of grammes :biggrin: in weight but to balance the brake pressure needed on the both levers? :sad:
anyone tried this?
and why is it such a bad idea?:smile:
tyred
Ireland
Several things spring to mind. The disks would probably be very hard to drill in the first place. It would probably increase the risk of the disk cracking. You would also need to really take the time to finish the job properly as any burrs/rough edges would tear the pads apart in a very short time and possibly cause stress risers.
gbb
Peterborough
Forget it, i don't think you'd ever be able to drill them...full stop.
PapaZita
St. Albans
Why not try a 140mm disc at the back? They don't seem to be very common, but they are available. I use one with my BB7s, because a 160mm disc wouldn't fit between the chainstays. Can't say I've ever noticed the weight saving, or any difference in the front/rear brake balance though.
PZ.
GilesM
East Lothian
PZ.
I use a 140mm disc at the back on my hardtail, braking's fine, many XC bikes do. As for drilling the disc, a tad hard I think, and it would/could weaken the disc, don't really fancy braking a disc, could end in tears.
