hi all,
i've recently purchased my first bike, a 1980's Raleigh Elan, however it's been rebuilt, powdercoated light blue and has prolite rims and conti ultras on it, really happy with the bike and enjoying it as such as i thought i would, however i'm after some advise on downtube shifters, my gearset is a mixture of tiagra and exage components, i have 8 cogs on the back and two upfront, at the minute i've mostly been using it in what i believe is top gear, big chain ring on the front, smallest one on the back, however i've found if i change down after a while the bike will change back up by itself and then sometimes back down again, i'm assuming this is could be me not using the shifters right, when i looked at it the other night i found the front derailler was right against the chain which i think was causing the chain to shift gears at the back, so i moved this off the chain slightly and it's now fine in top gear, but if i drop a gear it'll do the same again, that is switching between one off the top gear and the top gear at the back.
Any ideas? i'd appreciate a little crash course on how to use downtube shifters if anyone has one! my other question is do i need to go though all the gears on the back wheel on the main chainring - i'm assuming 8-16 before i should be dropping down to the smaller chainring upfront and starting again?
thanks!
thanks!
