My Shimano downtube shifter for my front derailleur has just started misbehaving and moving too far so it shifts the chain off the largest chainring!
It also now moves past where it used to stop in the opposite direction, which was in line with the downtube.
I've noticed that there seems to be a washer which has split and is now protruding from the shifter, which I'm guessing is the cause of the problem.
Can anyone confirm whether this is likely to be the case, and if so whether these can be got hold of fairly easily? I'd rather man-up and fix it myself, but if it's a pain getting hold of them might just head for the LBS.
