Hello everyone.
just recently i have been finding my fitness levels and ability to climb hills a little easier. with this progress i have been able to go from my usual local hills where i would use the absolute lowest gear and spin, now i am finding it possible to spin with the front gear on the middle sprocket (3 front) and the rear in the lowest gear (largest sprocket).
i have noticed the front gear cage is now slightly rubbing against the chain and have experienced a little chain slip every now and again.
i now i asked a similar question when i joined the forum last year, but is the combination of middle sprocket and largest rear sprocket a bit of a no-no, with regards to the angle of the chain. or is a slight amount of adjustment needed. i have tried the barrell at the gear changer but that just pushes the cage in the wrong direction and makes it worse.
i cannot seem to be able to use an allen key to try and take up a bit of slack on the cable as my bike is an spec sirrus, and the allen key will not fit between the cage and the screw thing.
any help advice would be really appreciated
