Does it really matter if your bottom bracket doesn't fit?
Andrew_Culture
Internet Marketing bod
I'm transferring everything onto a new frame and I can't get my BB in any further than you can see below. It's in firmly enough, and it's Dura Ace (much to my surprise!) so I'm quite keen not to have to buy another bottom bracket.
Mr Haematocrit
msg me on kik for android
:eek: Looks like a water trap to me.
I would not think that BB would last long fitted like that. I would also want to know why its no it fitting. This suggest a further issue.
RecordAceFromNew
Swinging Member
West London
It might have been for 73mm bb shell, unless the frame's thread is crudded up. You can introduce spacers. Some DA bb's like that have very specific (and uncommon) chainset compatibility - do you have a chainset that matches and gives you a suitable chainline?
ayceejay
Rural Quebec
Its not an Italian/BSA thing is it?
Are you screwing it in in the right direction?
I think you will damage the frame unless it goes all the way in.
TheDoctor
The TerrorVortex
Plus one side of Italian BBs is threaded t'other way round.
You can fit one side of a BSA BB into an Italian frame (although it's a bit loose), but the other one won't go however hard you try.
DAMHIKT.
Broadside
Fleet, Hants
You've got me thinking that I have refitted the BB on my wife's bike badly now as it looks a lot like the OP photo, might need to go and check the threads for 'crud '...!!
Broadside
Fleet, Hants
But does it ride okay?
Yes it rides perfectly. The play with the previous BB has gone and it changes gear nice and crisply so all is good. My wife never noticed that the previous BB was knackered, she thought the parcels in the post were presents I was buying for myself! She just gets on the bike and rides it, maintenance is my department!
I should say that I did have to move the front derailleur to improve gear changing but this was mostly because I had set it too low when originally fitting it a couple of months prior.
The comments above, particularly from mr H are making me wonder if something is wrong so I think I had better strip it down again.
andrew_s
Gloucester
I'd recommend putting a spacer between the frame and BB flange rather than leaving a gap.
It's relatively normal to make small changes in chainline by fitting a spacer, so they are readily available (eg Hope)
