Browser
- Crowland, Lincolnshire, UK.
Cycling to work this morning I saw at least two cars going the other way with sidelights on. This was approx 7:10 this morning and the sun had not cleared the horizon. According to the Road Vehicle Lighting Regulations, part of which is detailed here http://www.nmm.ac.uk/explore/astronomy-and-time/time-facts/lighting-up-time , headlights should be used "Headlamps are required on vehicles during the hours of darkness which are defined by these regulations as being the interval between one half-hour after sunset to one half-hour before sunrise."
Sunrise this morning was 07:31 so tyhey should have had headlights on, but I am assuing the old 'it isn't that dark and I can see OK' logic was at work.
Apart from when a vehicle is parked/stationary with the engine off and in a location which necessitates the use of sidelights to alert other road users to it's presence to prevent a collision, should cars now have a facility that when the ignition is switched on and the lights are switched/selected on, they should be dipped beams not sidelights?
Oh, and anyone with only one headlight working, please carry a spare lamp/bulb, check your headlights are both working before you set off and, if not, SORT THE BUGGERS OUT!!
