Does anyone else have problems signing in..
Shaun
Founder
Can you define the problem?
I'll then take a look on the VB support forums to see if we can sort it.
Cheers,
Shaun
Y
yenrod
Cheers,
Shaun
Basically, upon getting the page on ie i log-on then it resets to blank fields so do it again, and again and again...
Finally; it logs in' - it also does it too if I want to post a thread AND reply to a thread too ! - anywhere on the forum :ohmy:
Shaun
Founder
Can you confirm if you're ticking "Remember Me?" when you login?
If not, it could be that your login cookie is timing out - so you're effectively not logged-in when you try to reply / post.
Or ... having re-read your reply, are you saying that you try to log-in, but the username field resets and you have to make multiple attempts at logging-in before it finally takes?
Cheers,
Shaun
