I just wondered if I need to budget for some mudguards or whether they come with a new bike?
I assume they are fairly easy to fit?
The short answer to your question is no, you do not need to budget for mudguards as an extra, if you need a bike with mudguards you should buy one that is supplied with them fitted. (Mudguards are a good idea for touring and commuting, where the aim is usually to avoid getting wet and muddy, so are often fitted to bikes for this purpose, for mountainbiking and racing where the object is to get wet and muddy mudguards are commonly not fitted.)
As a second best, if your eye, for some reason, has fallen on a bike without mudguards ask the shop what the price is including mudguards fitted.
As some people have mentioned, not all bikes have the necessary drillings for mudguards, and there can be other things that can foul guards like front derailleurs, or clearances under the fork, so if you are buying a bike it is best to get these things sorted out before deciding to buy it. This kind of consideration just emphasises that if you want a bike with mudguards it is usually best to buy one being marketed with mudguards.
Now, about lights....
Unfortunately there are a lot of bikes that really should come with them but don't. This for example, a hybrid 'ready for the city streets' or a Carrera Subway. Cost cutting and I suspect it may also be down to them being easier to ship without the guards (more in the same container) as guards are more likely to get bent/damaged in transit than pretty much anything else on a bike.
+1 on buying it with them if you need them though - even if its the lbs that fits them
And when we see bikes that really should come with mudguards but do not, we should really go to another manufacturer and buy something that really is 'ready for the city streets' or as Dawes say 'ready for wet weather and fitting pannier bags': their Discovery 201 eq for example. (The manufacturer you mentioned also does ranges with mudguards.)
As you conclude the important principle is to go out and buy what you actually need, not a kit of parts that might or might not fit successfully.
Now about lights....
- .... And - 'Now about lights....' if you are suggesting that if we wish to ride in conditions requiring lights we should look for bikes that are sold ready equipped with them .... we will have a hell of a long search!
Exactly, we have to hold the line at missing lights, and in fact lamp brackets, otherwise manufacturers will start leaving off other things that they should include, and we will be back in the 1950s situation, when I believe keen cyclists bought the frame and all the parts for a new bike separately, for tax reasons.
WJH
Errr....quite a few forumites are still doing this anyway. Like me.
...... otherwise manufacturers will start leaving off other things that they should include, and we will be back in the 1950s situation, when I believe keen cyclists bought the frame and all the parts for a new bike separately, for tax reasons.
WJH
