When I lift up the rear of the bike (roadbike, Allez) by lifting the seat and give the back wheel a good freewheel spin, it will come to a standstill in 15 seconds. Is that about normal? Are the cones too tight?
I recently replaced the freehub + cones + bearings. I'm thinking that the cones are too tight and need slackening a bit.
Thanks
Imho one can't test / check bearing issues properly by just spinning the wheel - pawls/ratchet, grease, seals etc. not to mention the substantial inertia of the wheel all conspire to cloud the evidence.
Having taken the wheel off the bike, then it is a doddle to feel the resistance and type of resistance (harmful grinding of bearings or harmless grease/seal drag e.g.) by spinning the axle with your fingers.
+1 to the tiny bit slack gwhite suggested, and you can check that it is eliminated when feeling for play once the QR is tightened.
If the grease/seal resistance is not too great then a
pendulum test (with the chain off of course) as suggested by the late great Sheldon would also be effective.
