Do I try and replace my new freehub myself ? (PR-2 disc wheels 2017 with thru axle)
  • Thread starter Deleted member 35268
  • Start date
I've replaced a few 9 speed Shimano Freehubs before but not this one..
https://www.giantbikespares.com/Gia...mano&SRAM)--FH117K-01-/product_detail/3-43273
Looks like I just need a 14MM Hex Key and is not overly complicated.
My current freehub was at one point seized, but I managed to salvage it by injecting alot of lubricant. The issue now is that it has alot of lateral play so I figured it needed replacing (If it just needs a tighten inside I will be mad!)
Should I give it a go ???
Any advice ?
ianrauk
Tattooed Beat Messiah
Rides Ti2
Give it a go. If it's fubared anyway, no harm in trying.
If it fits you are OK. My guess is bearing number 9 on the diagram is worn. I've replaced the outer bearing on one of my freehubs after it developed play. Quite like formula hubs as they are easy to completely service and replace with better bearings when they wear.
I have no clue how to get this out.
I've finally managed to order a 14mm HEX key ...
Hello AGAIN. Managed to get a bit further with the freehub. Managed to get as far as this (the central thru axle can only exit on the drive side, and I could not release the two bolts on the brake side. Getting fed up with this little venture but I am learning alot about the assemly so not a bad thing for future maintenance. Will try again over the weekend to release the two bolts.
596926
596927
