Do i need a new cassette?
Austin Seagers
Hi CycleChat!
I've been commuting on a second hand raleigh for a few months now, and have recently taken it to pieces to clean everything up and get it rolling a bit smoother.
Having done so, I replaced the chain and rear derailleur as they were rusty and now have a problem with my gears slipping when I pedal hard on the smaller sprockets of the cassette...
I have taken a few snaps of it and wanted to know if I should consider replacing? I've spent a while adjusting my old and new rear derailleur to get the slipping to stop to see if it was the fact that i changed the derailleur, and no matter the tension of the cable, or old/new derailleur, the problem does not go away.
I've done some digging on the net and found that its generally good practice to replace a cassette that has had a worn chain on it for quite some time (which I have used every weekday for the past 6-7months of ~4miles per day)
Thanks, :smile:
Austin
lpretro1
Cassette well worn. Buy new one and problem will go away!
musa
Surrey
Replace cassette and buy a new chain again. So say maybe 6 months later replace chain. You'll get longer life out of cassette and chain drive.
Graham
If your chain is new (that's the impression I get from your post) then maybe just try a new cassette. The teeth on sprockets 4 & 5 do look quite 'stubby' compared to the others. Is it jumping in those gears?
A
Austin Seagers
Hi all,
Thanks, i purchased a HG41 cassette, and HG40 chain. I get skipping in all gears except the 24T sprocket. It gets worse the closer i get to the 12T sprocket though.
I'll update if it fixes my problem when i get the delivery (hopfully tomorrow)
Austin
A
Austin Seagers
Hi All,
I had delivery this morning and fitted everything a few hours ago.
After a quick re-adjustment of the rear derailleur, everything is working fine.
Here's some pictures for comparison with my older cassette with the new shimano HG chain.
Thanks for all your recommendations.
Austin
A
Austin Seagers
The chain is lubed... I didn't think the sprockets had to be?
