Do I have to have a reflector or is a red light okay?
heavens
I've used a light in the past but now that I'm cycling the roads I'm wondering if my red light is still going to be legal to use? I've got a front light too but have a reflector on the front as well.
BrynCP
Hull
You must have a red rear reflector if it's dark, in addition to your light.
"legal" is difficult, because it's my understanding that many(most) lights don't actually have the appropriate standards certification.
In practice though, just add a rear reflector and you'll be fine?
heavens
heavens
You need a rear reflector because you won't notice if your rear light battery dies during a ride. It is more important than your front reflector, at least you will know if you have a faulty front light.
Shopping time! Just thought I'd check first and see if I could save a couple of quid. :thumbsup::thumbsup:
There's a guy I see most mornings who always dresses like a ninja and doesn't even have a light, never mind a reflector. I saw him go down the slip road onto the dual carriageway the other day in the first light of the day :eek:
+1
i think the 'main' legal one has to be a steady ON light
so the second can be in flashing mode
There is another thread on lights at the moment (http://www.cyclechat.net/threads/approved-legal-lights.167445/post-3336196)
The problem is that if you have a flashing light the light does NOT have to have a BS6102/3 certification to be legal, but to be used in permanent mode the light MUST have a BS6102 certification... the light can therefore be both legal and illegal depending on the mode!
Your planning is also important with lighting
The charging cycle is what guarantees your light not failing during a commute charge regularly with a programme and you will not forget
Personally I have two lights, one in permanent mode and one in flashing which means one will long outlast the other
When you purchase try and buy lights that have a life of twice what you need!
That way you know that if you have an issue, stop off for a chat or detour then you will have a safety margin
In my case I have a 1 hour commute,my front lights have a 5 hour life and my rear 4 hours
BrynCP
Hull
Only saying what the law says. I did say right at that the top that in practice it doesn't matter so long as a reflector is present.
