gbb
- Peterborough
Steady day at work allows me to give the bike some TLC....here's what i've done....what have i missed?.
General clean with soapy water, wipe dry, compressed air to blow out those hard to get to areas.
Remove brake cartridges, clean, inspect for debris.
Remove chain, clean liberally with WD, blow out links with compressed air ( you'd be amazed how much crud comes out of a cleanish looking chain when you give it a good blast with air), soak in a tub of oil, wipe clean and re-fit.
WD the cassette, blow out with comp air. Gets all the debris out nicely from between the cogs.
Oil the jockey wheels (after removing debris and dirt from the derailleur)
Clean the chainset with a cloth, lightly soaked with WD.
Have i missed anything ?
What can i use to give my slightly aged Conti Gatorskins a newer look (particually on the sidewalls). Washing them cleans them, but they look a bit...well, aged. Shoepolish maybe ?
Celeste bar tape ? Looking dirty, any suggestions ?
