DIY electric Brompton: Reviewed after a couple of months in service.
Kell
Interested to see how you get on.
Was it significantly cheaper than the likes of Swytch?
ColinJ
Puzzle game procrastinator!
Dimensions are 360x90x110mm, weight isn't stated. It's an Aliexpress one, so I factored in it being about a third of the claimed capacity, which will be plenty for what I want.
That's what I was thinking... It would have to be 2 or 3 times that big to hold as much energy as they claimed.
I hope that it turns out to be a successful project!
Drago
Probably no more or less than about 75% of the battery vendors out there. It'll be treated with the same levels of suspicion as all the Li-Ion batteries I own.
You'll need a bit more than suspicion to help you if it goes all willie-pete on yo' ass.
Unless you're charging it outdoors, 10 or more metres from the house, you'll need more than suspicion to protect you, like a 3" thick cast iron box with asbestos lining.
I've heard of folk putting them in biscuit tins and the like thinking that'll protect them if it goes off. It won't.
As for the rest of it, great project.
albion
Gateshead
That seems cheap... does it include a battery?
EDIT: even if it does, apparently their standard battery is only good for 9 miles...
Tiny battery. Good enough for short commutes.
A fit for the typical Brompton user.
CXRAndy
Lincs
Really suprised on the range for such a big battery. Usually the jumbo battery has around 20Ah. I know this because I have the slightly smaller dolphin battery with 17Ah
The range on the wife's TSDZ2 motor kit has around 50-60 miles. This is a crank torque sensing motor, with custom firmware
tds101
Grumpy old man waiting for the weather to ride...
New York, USA
It's most likely one of the purposely mislabeled batteries. They'll sell it as "20 AH" and it's more like a 7 AH battery. As long as it suits your needs, you'll get your monies worth.
