Disk brakes conversion possible?
PimpMan
Regular
I have basic frame old school beach cruiser i want to install disk brakes in the front only.
1. How to mount rotor my wheel hub is basic no thread or mounting holes it. Do i need to purchase new wheel or there's some adapter?
I found this thing it threads on the hub, am i supposed to use rear hub in the front to bolt it on?
2. Fork has no mounts for calipers i think this $6 adapter should work?
Cycleops
Accra, Ghana
Certainly possible. You'll need disc hubs to be laced to your existing rims or new wheels. There are various adapters you can use to mount the callipers.
RJ the bike guy has a video on it which might be useful.
View: https://youtu.be/emW7M-ZD0Pw
greenmark
Geneva
This really is a solution looking for a problem. And once you've done it you'll have other problems to contend with.
That adaptor is for converting disc hubs that take centrelock rotors to accept 6-hole disc rotors. It would not be possible to convert a normal non-disc hub to accept discs. Disc wheels have a dish to them – which means that the hub spoke flange for the disc side is in-board compared to the flange on the non-disc side. You can't move the flanges on a non-disc hub. For disc brakes you need disc-specific hubs.
As for the fork conversion, the non-disc forks are not normally engineered for the brake forces from discs. They’re engineered to have the brakes at the ends of the forks, near the rims. At best your forks will flex excessively when braking – they will feel like noodles when breaking (braking) and it will make your handling extremely difficult. At worst the forks will deform or snap.
Lastly, even if you do manage to get front discs and rear non-discs, your front/aft braking balance will be completely off, which will further make your bike difficult to handle.
EDIT: a few mea culpas for braking noodles
Loch side.
As for the fork conversion, the non-disc forks are not normally engineered for the brake forces from discs. They’re engineered to have the brakes at the ends of the forks, near the rims. At best your forks will flex excessively when braking – they will feel like noodles when breaking and it will make your handling extremely difficult. At worst the forks will deform or snap.
Ahmen.
But do a few mea culpas for those breaking noodles.
ozboz
Richmond ,Surrey
I had this idea , but as said if you want disc brakes buy a disc brake bike, but as you only want them on the front , if you bought some forks and front wheel that were manufactured for purpose then maybe you could ,
BrumJim
Forum Stalwart (won't take the hint and leave...)
Converted my bike to disc on front, callipers remaining on rear.
I bought new forks for the front, which is the most sensible way forward. The wheels must have been disc ready (new, probably). Bike shop did the conversion. There was a small problem with the mudguard stays which was resolved with a bit of bending.
The brake balance thing seems to be nonsense. Most braking is on the front anyway.
Globalti
It can work if you buy new forks from Carbon Cycles and a new wheel. But you'll also need a new right brake lever.
